The gap doesnt change when you add bigger wheels, assuming you keep the diameter the same (you should get as close as possible). It just becomes more apparent is all with the thinner tire.
I guess you could possible drop it too low and have issues but that is where adjust-ability come into play. If you stick to sizes and offsets that others on here are running you shouldnt have any issues.
