      01-15-2013, 12:29 PM   #7
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Originally Posted by itdnwiwbp View Post
I also asked them about torquing to 30lbs after I was unable to find an appropriate 5.5mm hex socket anywhere. They said all that was necessary was to thread it in until the threads bottom out then stop - the loctite does the rest.
I took that from the install instructions from the APEX website. There was no issue there. As for letting the car rest on jack stands, I hadn't heard that anywhere before so didn't do it. If there is an issue I can reset them using this method.
