Originally Posted by elerner61
You mention only one drain plug. Did you drain the block? (that could be called a "2nd" drain plug)
No, I meant the plastic drain plugs. M's only have the one on the bottom of the radiator and not one for the expansion tank. I did not want to mess with the block drain.
