Originally Posted by v8z4
I've always assumed it (5 speed) was (slightly) lighter than the T56. All and all, total weight change is likley within 150lbs either way. Some things are getting lighter, other things get heavier.
I imagine overall it will not be that bad, probably at most 75lbs difference. The Ls3 is the lightest of the bunch at around 415lbs, so that's only 40lbs off a M54. Amazing.
