Originally Posted by The HACK
The fronts will need spacers. Takes an 8mm spacer to fit, and it's super tight (like a few mm at the back of the spokes). If you run a squared setup, the rears will fit up front without spacers, but you'll need some significant camber to clear the fenders. I've gotten the tires to clear the fenders at -2.5º up front using the rear wheels.
so the issue is not about the diameter being an issue but rather the calipers being thick as an issue. thanks
