Originally Posted by pungo
The Z4 headlight use permanent glue to attach the lens. The lens is typically cut off to install the LED rings, then the lenses are glue back on. It's not a typical DIY project.
I did some dual LED rings, check out this post.
Do you know what size the lenses are? I know the smaller ones are 70mm. What size did you use for the big one?
