      07-12-2014, 05:34 AM   #10
Beedub
car looks awesome!!
and I'm from the Caribbean ;-)
the pss run wider anyway so be careful running that 285, however as you don't do any track work they may be fine!!
BTW my front 18x8.5 et 29 rubs with -2.7 deg camber, albeit the lightest of light brush and not enough to rub through fender liner, you will never convince me that front/rear doesn't rub when the car is used how it should be used.
