      09-23-2012, 03:36 PM   #750
Beedub
the aem has a built in check valve in the knozzle.... so basically its failed!! unless you have an early kit without it....
tom... sill think you may want to do a thorough engine check..... the engine injesting a cups worth of fluid wont have helped it in any way... remember youve found a cups worth left in the pipes... we dont know how much its actually injested.....
hmmmm..... meth/water..... awesome thing but sadly just another thing that can fail.
what went wrong.... theirs no way that should be leaking into the boost pipes....
heres the bumpf of flooded motors
A severe form of engine flooding occurs when excessive liquid fuel enters the combustion chamber. This reduces the dead volume of the combustion chamber and thus places a heavy load on the starter motor, such that it fails to turn the engine. Damage (due to excessive compression and even dilution of the lubricating oil with fuel) can also occur. This condition is known as the engine "flooding out".
