^using ur rear wheel measurements, 10" et27, calculators show 10mm less clearance between the inside of the wheel and the strut housing compared with stock. for 9.5" et35, i'll contend with 11mm less clearance, which according to ur eyeball estimation, should still clear on the inside with barely 7-8mm to spare. on the outside, 9.5" et35 will extend outwards by 1mm over stock, so next to negligible. granted, running 10mm spacers on the rears would give the perfect, flush look, and give more clearance on the inside of the wheel. thanks for ur input!
still, really pinching myself hard not to bite the mod carrot again....
