Originally Posted by Roffle Waffle
Its at the shop getting water/meth installed, and the boost leak investigated. So far a small leak has been fixed, and the guy thinks he sees another suspicious location. Should be done by friday
What's the situation with water/meth? Are you going to adjust the ESS tune at all? You're not worried about losing ESS warranty so early in your install?
I am so intensely tempted by water/meth, and eventually will go there after the standard kit is operating perfectly for a while. Free power, consistency, and motor safety!
