Originally Posted by jonathan3zimmer
thank you thank you thank. that wire is seriously hard to find...especially in the dark and when you can only get a couple fingers in there. now all i have to do is order the button. when you drilled the hole for the button did you take it all apart or did you just hold back the wires and drilled into the console?
Well, I did both... The first time it cost me a replacement console top... plus I had metal filings all over the place. DO NOT try to do it without removing the console... It will take you an hour to remove the console... but you should plan on your car being down for a day... if you remove the console, you will be able to see the outline of the hole that has to be drilled out... In order to remove the console, you have to remove the rear storage area cover (the storage area between the seats).. If I can help, let me know... Chuck I
