The painted steering wheel trim is holding up fine. Still looks as smooth and piano black as the day I did it. I think as long as the edges of your CF wrap arn't at a place where you touch often, it should hold up.
The trim area isn't a place of constant contact; I just think that the original rubber coating is very susceptible to degradation. CF wrap should be fine.
