Originally Posted by IWantAnE92
Did you get this working in the end? Or has anybody else confirmed whether it works or not?
Never got a chance to try those particular wheels on, they were sold before i went to pick them up
With stock suspension if you max out your front camber you SHOULD be fine, if there is any rubbing at this point i think you would only get it at full lock.
I only know of 3 members to try the e92 wheels on. F360C (
http://www.zpost.com/forums/showthread.php?t=460759), EndlessZ4M (
http://www.m3post.com/forums/showthread.php?t=467130) and Taku (
http://www.zpost.com/forums/showthread.php?t=160440)
F360C and Taku both said you'd need a fair amount of neg camber to be on the safe side and not rub. EndlessZ4M however, was on stock camber and I don't believed his wheels were rubbing, but i could be wrong.
