Thanks for the reply. The header motor and gears are working fine. They had gotten out of sync with the window cycle. I've been disconnecting the battery and while working on the roof and it needed the windows to cycle for the header motor to run correctly. It's the roof opening/closing that is the problem. At this point I have the motor out of the car. When connected to a battery the 12/14 port will push fluid out in a good stream. I reversed the wires expecting fluid would pump out of 11/13 port. But nothing came out of that port. A couple more drops came out of the 12/14 port but not much. So I need to see if I can find info on how this pump should be working.
