Originally Posted by Beedub
awesome thanks for this so.....
on the rear be careful with washer layout.. bear in mind im using Re mounts...
Only need to remove the tray, is this difficult or piece of piss??
the fronts im always very careful with the nuts, Tq figure is 35nm.... will grab the tis to get Tq figures for all parts.... all in all, is this something you felt comfortable doing??
ill then drive to a shop to get alignment.... i will be trying to lower the car the minimum amount possble....
no its fairly easy and straightforward, just take your time, and have a good torch (flashlight) by your side
