Originally Posted by seank
What I can't figure out is how my belt is 2360 (vs 2310 it's suppose to be) and they are going to send a larger crank pulley. How's that going to fit?
Probably you've never been able to take advantage of the kit. To increase the speed of the compressor you can:
-reduce the pulley on the compressor or increase the lower pulley.
... maybe you had posted/installed the belt correct with a wrong low puleghia.
