Will this setup fit on the front of the M?
I'm running 245/40/18x9 ET42 on the front right now. Tires are BFG Rivals which are pretty wide. Stock suspension. No issues with rubbing. I am trying to fit camber washers on but the tire rubs on the strut. So I would need spacers.
Assuming 5mm spacers clear the strut, my setup will essentially be ET37. Will I rub on the fender?
What about 12mm spacers? ET30? (I doubt this would fit but you never know).
Camber would be maxed out to whatever I can obtain with the 2 washers and stock suspension. Right now camber is maxed out at ~-1.1* each side.
