Originally Posted by Chuck I
To me it looks like it should work for both. BUT, I won't know if it works at all until I plug it in. My hope is that the software is there... From the way the switch is built it looks like the light will function but I'll have to wait to see if the DME and the EPS will respond. I know that on my M, the Sport button make a difference so I'm hoping I'll be able to tell the difference here. There's another issue, your connector may not be there. As you can read above, JRA's car didn't have it... My car is a very early unit built in 12/2002. I lucked out. My suggestion would be that before anyone buys the switch that they check to see if the connector is there. You can get the switch for less than $80, probably cheaper if you shop around... Chuck I
thanks for the info. hope this works.
