Just an update - I put 5mm spacers on to clear the struts with 2 washers. Getting an alignment tomorrow, from what I've read it looks like 2 washers on stock suspension can yield ~2.4* negative camber, so hopefully I can obtain that. If that works, it will end up being 245/40/18x9 ET37 (42 and 5mm spacer) with -2.4* camber.
