Originally Posted by Ibanezrg31
Hi guys,
I need some advice on wheel fitment. I have an 3.0i and will be installing koni yellow suspension with H&R coilovers which is about a 35mm drop. I will be running 18" ellipsoid 107 wheels.
My goal is to have an aggressive setup that doesnt rub but is flush with the fenders.
Can anyone recommend tire fitment options?
How wide can i got with these wheels?
Also I heard to get these wheels to fit better with flush i may require spacers, whats a good spacer to use with the setup im looking to achieve?
Current oem 107 wheel info for reference:
Front 225-40R-18 8x18 ET47
Rear 255- 35R-18 8.5x18 ET50
Thanks everyone!
The more you drop the less the car will look flush with stock wheels because he drop will induce camber and the wheels will be then be more tucked in. Wider tires will only do so much and frankly I wouldn't go wider than a 255 on a 8.5". You could go wider up front but then your overall diameters won't match between front and rear.
You need new wheels with lower offsets or run spacers like 12 and 15mm. Apex sells spacers that tend to be cheaper than others. That's what I run on my Z.
