Originally Posted by pbdm4k
Oh... and since Patton thinks I'm useless...
Don't forget you NEED to work in a diff. Find an empty parking lot and start doing figure 8's!
They aren't plug and play. They need to be worked in otherwise it may be causing the whining you're experiencing.
you do know that break in procedure has nothing to do with the ring and pinion, but it breaks in the clutch packs that make the diff lock right?
