      01-10-2016, 11:03 AM   #60
Westersund
Westersund's Avatar
Sweden
501
Drives: BMW
Originally Posted by pokeybritches View Post
Not on a 1000 hp car. The cost of the block is nothing compared to the rest of the build.
There are other factors, like tuning, and the S54 sacrifices low end for a higher redline and better flow up top.
The cost of the pistons and rods are similar in both builds, but the availability of M50 blocks are so vast the cost is basically meaningless. If you want a S54 block on the other hand you more than likely will have to buy a complete engine or a block from BMW, neither are cheap.
Depends, if you're comparing a 700 hp M50 to a 1000 hp S54? If that's the case the M50 will probably have better response. Overall the S54 is a better engine, in all regards except thinner cylinder walls. But if it's a sound block from the get go that won't be a problem.
