      05-19-2014, 10:29 PM   #70
shibby170
Drives: 2007 Z4M Roadster; 2017 M2
Originally Posted by XMetal View Post
For the center roof, I ended up using a 5LED 194 (shown in the attached picture). It won't fit through the hole opening, but you can easily remove the plastic cover (2 screws) to installed the bulb without needing for it to fit through the socket opening. I found that this 5LED bulb glows much closer to OEM (in terms of brightness) than the single LED.
For the trunk (boot), I used the 16LED festoon. Since the trunk only have 1 bulb, I want the maximum luminescent out of the bulb.
Can you provide a picture of the "two screws"? I see two things that look like they may be the screws you are taking about, but my screw driver doesn't fit in the narrow passage way to them.
