      07-16-2012, 06:13 AM   #53
gtMc
gtMc's Avatar
21
Drives: '08 MC
'03 e39 m sport  [0.00]
'08 mc  [0.00]
Originally Posted by Kgolf31 View Post
Levels will vary on tire compound, size, what you're running on, how hard you run it...etc
If you're really pushing it, a good indication is the tire arrow:
Those are my RS3s after my first auto-x. The arrow indicates where the roll-over mark should be. All tires will roll over the sidewall, adjusting pressures to make sure they don't roll over too much/little is key.
I dropped 1 PSI in the rears and now I'm golden. I run 35 hot rear, 39 hot front on my RS3s for autocrossing.
Ok - I'll look for this tonight when I get home. I know it takes some tweaking to get them right. I also need to take a 'cold' reading, will do that soon too. thanks...
Originally Posted by Dubbedown View Post
tires > suspension
=D
Dan, yep it was a great move to upgrade the tires before thinking of doing anything else!
