Originally Posted by gtMc
yeah i was going to ask about this. so I did check the tire pressure twice, once when they were warm after about 25 highway miles, and once halfway thru the drive when they were hot. Warm was around 35psi and hot was 37 psi. Do those levels seem ok? I think it says 32psi cold inside the doorjam... As for checking 'tire-roll over' . . . not really sure about that.
Levels will vary on tire compound, size, what you're running on, how hard you run it...etc
If you're really pushing it, a good indication is the tire arrow:
Those are my RS3s after my first auto-x. The arrow indicates where the roll-over mark should be. All tires will roll over the sidewall, adjusting pressures to make sure they don't roll over too much/little is key.
I dropped 1 PSI in the rears and now I'm golden. I run 35 hot rear, 39 hot front on my RS3s for autocrossing.
