Originally Posted by ZStig
Right now I've spent too much money trying to keep my car running. The last thing on my mind are upgrades.
New alternator $750 (wrong diagnosis by me and friend), new fuel pump ~$600, new crank sensor $160, new battery + diagnosis $350, new starter plus install $350. And now I might need to replace my fairly new fuel pump because I had stalling issues a few days ago.
as per my other thread
"I was told that my 320 CCA, 16lbs battery didn't have enough cranking power and was causing issues. Replaced with a 34lbs 650 CCA battery. Worked fine for a few days
Then I had issues with the car stalling after a long drive with some heat soak, and not re-starting. Clicks but no crank. Diagnosed with a bad starter, and they said it was probably killing my small battery. Installed new starter.
So car starts fine now, but I had a hard code for low fuel pressure and fuel pump when I brought it in for the starter job. I have a 3 month old Aeromotive 340 pump in the tank, with a new OEM fuel pressure regulator/filter. I'm really upset, and hope that by some miracle the fuel issues were caused by some sort of shorting issues in my starter.
I really don't want to replace the fuel pump if I don't have to. I'm hoping the code doesn't come back. Thankfully my fuel pump is under warranty, but this might be the last straw for me if I have to replace it"
oh shit........ sorry to hear this.... ...... ...... cars can be bastard right when the finances are fucked...... good luck and keep us posted!!! i'd noticed youd been very quiet as of recent...
good luck buddy.
byron
