Same here, assuming it's of recent vintage. Grommets, as well.
I had a go around with valve timing after getting INPA and finding that the "mechanic" that replaced my Vanos bolts did a shoddy job of the valve timing.
Took me 3 tries to get the timing correct, on a 6 month old valve cover gasket.
No leaks. Just make sure you carefully remove the cover leaving the gasket flat on the head.
Gotta wonder why 2 out of, what, 13? grommets are Buna.
