      06-27-2014, 09:54 PM   #9
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Originally Posted by donoman
Originally Posted by The HACK View Post
Tire deflection or worn out trailing arm bushing. Do you have RTAB limiters in?
I don't have RTAB limiters in the car, thank you for the suggestion! I will check the RTAB's, as well. I have not looked at them yet.
That size should work I'm running 18x10 Apex EC7's with 285/30/18's hankook TD's lowered on KwV3's on track and not rubbing . Def check out you're rear suspension .
