Originally Posted by donoman
dorifto88,
Hrm, I rub at high compression, like big bumps.
I can get it to not rub (on the street) if I raise the car up by dialing in more preload. So I can raise the car up, which is an obvious solution... but I'm worried that it will still rub at the track.
I can't raise my compression damping (only rebound), if that was what you meant?
sorry yes thats what i meant. like above said, it will eventually go away. thats just plastic (where its rubbing). i think it is safe to assume that all, or most, of us who autocross or track the car rub there, and in the front also. If the rubbing really bugs you then try a 265 tire instead.
