Originally Posted by 007MCoupe
You installed the steering wheel on the wrong side!
hehe, might want to fix the steering wheel location before you get too far along
How did you do your trans mount (do you have a good shot of the mount in the car)? Is your shifter mounted to the tunnel or the trans? If mounted to the tunnel, what trans are you using?
I see what looks like a small surge take for the fuel system. Are you using the factory pump to pump out of the fuel tank (to the surge tank) and then an external pump to pull from the surge tank to the engine?
