Originally Posted by RobMCoupe
I've been researching tire sizes for my 19" setup. The recommended up size is 245/35 front and 275/30 rear. They are slightly smaller diameter than stock. Assuming 19" wheels are same weight as stock, you'll loose weight because 19" tired weight less than 18" tires.
I think the choice between 18 or 19 depends on what is most important to the owner. Look, performance, ride , tire selection, etc....
Nono, tires for 19s should weigh more usually. They have to reinforce the carcass since they've got shorter sidewalls and less room for error so to speak.
