Originally Posted by md2mhk
Omg a pressure bar? Please find a shop that uses a Hunter mounting machine!
Even the Hunter TCX575's use a press bar. Its to separate the bead from the wheel. There are actually 2 components that do this. At SOME point, there WILL be forces placed against the rim edge to lift the bead away and on/off.
I'm not sure what else your referring to ?
And I would imagine only a high end repair /service center will have that in Mexico.
