Originally Posted by Dubbedown
Thanks I just ended up mounting it via suction to the rear hatch but I may try using this cable.
Stupid question but are you saying the iphone will work fine with the emprum even in airplane mode as long as wifi's on?
The idea is, the GPS unit should have a clear path to the satellites. Windshield, rear hatch window etc should be fine. I mount mine to the iPhone directly which is mounted to the windshield.
The airplane mode is for the WIFI OBD2 units. The GPS unit is connected to the iPhone directly. But the OBD2 unit is connected via WIFI, and people say that there may be interference caused by the 3G signal.
