Originally Posted by E90PAT
What additional hardware is required to make your Karbonius work? I am coming across threads for M3s discussing MAP sensor mods, splicing wiring, and some crazy ones like DME swaps. Did you order for your z4 or did you order an m3 one form them to which to had to shave or modify the airbox to fit.
Originally Posted by rockstar93
Same questions here - this will be my next mod too.
E90PAT and Rockstart93 hello. Assuming that you have a Z4M if you decide to go with the Karbonius, the additional parts that you will need are the following:
CSL Crank Case Vent Hose 11157833649
CSL Airbox Air Shut Off Valve 11617833647
6 x Clamps 59 - 66mm - 07129952125
OEM CSL filter 13727838625
CSL IAT Sensor 13621739510
Karbonius Snorkel - £300 (optional - I do not have it)
Tuning - you must have Alpha N tune to make the Karbonius work with the car. Tuning is the most important part so choose wisely. Known tuners are Epic Motorsports (my selection), TTFS (I do not have opinion about them but I guess it is a good choice if later on you want to go the SC way), Evolve, ESS.
The car after the Karbonius and the tune pulls stronger. But the best part of the CSL intake is the sound... You can have a look here:
https://youtu.be/NDoNhiNBrxo
Also you can see my comments about this mod here:
http://www.zpost.com/forums/showthread.php?t=1422706
