Originally Posted by beta
Don't want to be specific, but less than a new one (with deposit), and you can ship yours to him to get your deposit back.
So I figured and I'd hijack my own thread, to turn it into a how to do this. I'm considering sending him a new one instead of a used one, not sure it's worth the money or not.
Parts list:
1x Exhaust Hub 11367832031
12x interior vanos hub bolts 07129905536
1x vanos gasket 11367831938
2x banjo bolts 07119905175
4x banjo washers 07119963072
Parts shared with valve adjustment:
1x Valve Cover Gasket 11127832034
6x Spark Plug Hole Gasket 11127831271
2x Valve Cover Seal Washer Grommet 11121437395
13x Valve Cover Nut Grommet 11127830972
2x PCV Return Line Gasket 07119963129
Tools:
11 9 130 / 83300493749 - Cam Timing Tool
11 7 342 / 83300491086 - Extra Cam Locking Pin
11 2 300 / 83300490861 - Flywheel Locking Pin
Optional tools:
11 7 160 / 83300493805 - Vanos Adj of Spline Hub handle
11 5 100 / 83300491056 - Crank turning fixture
DIY links:
SYT Shadow DIY
Hutch 430 Part 1
Part 2
Part 3
Part 4
Part 5
Part numbers for special tools
I need some help with the tools I'll need. I imagine I need a set of small spanners. I'm also going to need a small torque click wrench. I was hoping for split beam (as they don't lose precision, nothing under tension), but they don't seem to make them for small numbers like 10Nm. I like to get the best tools I can afford and pass them down to the kids.
Do I need to jack the car up on the Z4M? or can everything be done from the top?
Hi everyone
You guys can follow my DIY on the other forum. You can access everything through the top.
The only difference for the Z m is you need the water pump tool as there'd no fan clutch.
I have 27k miles on my V3, including track days.
The best part of this design is that if it fails you just get a CEL. No possibility of a tab destroying your engine.
Feel free to ask questions.
Cheers
