      05-17-2017, 10:53 PM   #198
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by 03z4 View Post
When I originally picked out my wheel setup someone on this or another z4 board stated that this size combo worked out be be the closest match for final resulting size between 8.5 and 9.5 wheels. Was actually the front that was "taller" being the 40 series. But to be honest the combo was a very good match visually you could not tell a difference.
I believed what "3002tii" meant was your new tires will be:
Front sidewall height: 225mm x 35% = 78.75mm
Rear sidewall height: 255mm x 35% = 89.25mm
So the rears on your new setup WILL be "taller" than the fronts
Your previous setup are actually much closer matched with the rears just slightly more "taller":
Front sidewall height: 225mm x 40% = 90.00mm
Rear sidewall height: 265mm x 35% = 92.75mm
