Originally Posted by Mirko
How is your alignment? Also what is your PSI at for each tire, could be too high or too low.
34 front and 38 rear. I only put about a mile on the tires because I was busy.
I'm starting to second guess myself. If it were bearing noise it'd have to be all four wheels. The car has 60k miles...
The noise doesn't change if you jerk the wheel from side to side and is still there all the way to a stop..I test drove another one that made the same kind of noise a few weeks ago but I don't remember it on any of the other z4s I've worked on..
I'm going to try to get over to the shop today and put it on the lift to have a listen.. I could just switch them onto another BMW on monday too.
