I did this last weekend. Obviously, they did not use any sealer from factory. But I noticed that some butyl is used to seal the glass to the frame. So correct. This is purely for cosmetic part.
I also noticed that there are notches at the center of rubber strip and on the car. So you match these notches to center the strip when you install it.
Very easy to do.
