Doesn't TIS give a torque spec?
I mean you use an existing bolthole for the bracket don't you?
(where there used to be a factory fitted bolt)
Blue loctite can't hurt in this situation.
If you have the bolt size, bolt quality and thread pitch, there are generic values for bolt tightening torques.
