Originally Posted by johnkuo
I went to my local muffler shop and they put the car on the lift. It looked like it's already as high as it gets without bending anything. I'll have my indie shop take another look later. I'm not sure exactly what else can be done to it.
And you've made sure to... Rotate the flange so the bolts are aligned vertical to the ground, and tighten the top bolt first. Leave the bottom bolt loose until desired height, then tighten bottom bolt.
