Going back off-topic about the V1 - I did not find a switched power source in the over head console on my '06 ///MR. At first I thought I did, but it ended up being the power to the 2 LEDs that shine down on the shifter. So I ended up running the wire down under the ashtray/switch console & placing the power adapter there as there is plenty of space. I tapped into the wiring harness of the radio for a switched source. I then continued the V1 wire above the steering column where I have the remote display module.
