Originally Posted by wdb
It should be pointed out that, in the US at least, the brake ducts are blocked off from the factory. Two little plates that are easily removed to allow air flow through the duct into the wheel well.
Same in Europe, however even with them removed they don't direct any air at the discs. The wheel well will however be filled with air which both has it's pro's and con's.
