Originally Posted by Panchio
But I guess If I get rid off the Run Flats I might save some weight on the tire no? I assume that Run Flats are heavier just becasue the type of tire...
Run Flats are heavier, ride worse than standard tires, and they're double the price.
Stay away from those and stay with Hankook tires that you had chosen. Your ride will feel much more planted and compliant.
