Originally Posted by Shipkiller
Now I have a question.
If you buy a used BBK, how do you know they are good? Do you have to search for a rebuild kit? Do you have to rebuild it?
I am not adverse to using a 'second hand' brake system, but how do I KNOW it's good?
Rebuilding calipers is not something that needs to be done often IMO, but you could inspect the seals for leaks. Aside from that, unless the caliper gets stuck/siezed, I see no reason why you'd have to.
The only parts I'd get new when buying a bbk is stuff like new crush washers, new bolts for brackets, etc but all that stuff is relatively cheap.
