Maybe not the best fun if the car is a slower car. In the E36 race car which has a top speed of 119mph, you could probably get a mani-peti between some turns. I did over 400 miles on-track the first day working the entire asphalt surface…couple laps inner, the outer, then down the middle, then on the race line, etc. The corner worker that sits on the bridge support right before the start/finish thought I was insane. Lap times got down into the 2:31-2:32 range, and then I dropped a valve.
