Originally Posted by Finnegan
Do you have access to a BMW code reader and software? It could be a lot of things, but chances are there's a code that could pinpoint if for you. You can find these really cheap on Fleabay or Amazon. For 25-50 bucks it's way cheaper than trying this or that.
I may drop by Advance Auto and borrow their scanner to see if there are any codes. Thanks for the suggestion!
Also, ruled out any potential battery issue - Left it on the trickle charger for 2 days to no avail. Pressing the gas pedal seemed to get it to start on the first crank, albeit longer cranking time than normal (or second try).
