Originally Posted by Bossdog
If you are going to install a more aggressive Front sway bar for Track use ( as many do) read THIS thread and THIS thread
If your car will be mostly Track, the Clubsport coilovers, See THIS Thread and THIS thread
If you have searched, you've probably seen all of these.
The HACK says THIS Code change is the best Track Mod you can do to your car.
Not many Z4MC's out there, fewer yet being tracked.
Good Luck! Have Fun!
thanks a lot!
I read about the subframe problem, but I dont like getting sway bars until I have my coilover dialed in.
about the coding, that is pretty impressive! However, at the track I just turn everything off.
Just a question, if I want to get coding, is the ECU same as e92?
