View Single Post
      06-16-2014, 01:14 PM   #53
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Originally Posted by 3002 tii View Post
Handling was great, cornering felt more neutral than before and turn-in was even better. The only complaint I had was the rear end getting very squrimish under heavy braking, the back end would get real darty. So ended up dialing out some camber in the back and I settled with -2.8 front and -2.6 rear. I'm taking the car out this weekend at Watkins so I'll report back again.
I found that I was rubbing in the fronts but I think that's a reflection of the rather soft springs I was running relative to the r-comp tires. I just bumped up from 450/550 to 550/650 and added a thicker front sway. I was rubbing in the rears slightly but a quick fender roll addressed that. The rears are really easy.
Called the local shop and the guy told me if he has to roll the rear, the fender might be warped because the Z4 has such thin sheet metal. I should probably start a new thread for this.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
