Originally Posted by iPhoneEngineer
Oh man, I definitely didn't want to increase my limiter...having a relatively long stroke and a high redline, our motors are already dealing with huge forces stock, so adding in the S/C I'd be pretty scared to push my luck further
im definatly with you on this one :-) i left mine well alone!!
Tom your Redline will be increased to 8200 if your requested the high rpm limit, which will net you Even more boost
:confuse d0068: about another 0.25-0.5 infact ;-) if you get an 8psi pulley like i think you have, your getting very close to the 9psi the vt2-550 runs.... you may well have the most powerful z4m with the ess kit :-)
