Does anyone know the max negative camber we can generally achieve on a non-M Z4 front end by simply removing the strut pins? Can't find that info anywhere.
I just received a set of Apex ARC-8 17x9et30 wheels and plan on running 245/40r17 RS-3's in the front. Trying to get an idea if I need camber plates to fit without major rub (I know it will be close without them, if it even works at all). I would prefer to NOT have to buy the plates.
Thanks!
